Author Topic: My hardrive won't format.  (Read 938 times)
Offline Juan-PedroMartinez
  • New Registration
« on: November 17, 2003, 22:21 »
I've been trying to reformat my hardrive but it keeps failing.  I get a message telling me to close all windows showing the drive content and any utilities using the drive.
How do I make sure that all such utilities are closed?  And if that's not the problem, then what could it be?
I would appreciate any help.
Re:My hardrive won't format.
« Reply #1 on: November 17, 2003, 22:34 »
:welcome: Juan.  One of our techies will be along very soon.
« Reply #2 on: November 17, 2003, 22:38 »
Hi Juan Pablo and welcome aboard.
If you are using XP and are trying to format your boot drive/partition from inside windows then I dont think it can be done.
The format option doesnt actually function as such.
If you have a boot disc on a floppy then set the bios to boot from floppy and when it boots to the A prompt type Format C: and press enter  :-*
If you need a boot disk you can get one from :
www.bootdisk.com
Offline firfirikos
« Reply #3 on: November 18, 2003, 22:06 »
Or else you can put winXp cd (If you are using winXp),press R for recovery,and then type Format C:,like Sandra said.
here is no dark side of the moon really. Matter of fact it's all dark...
« Reply #4 on: November 19, 2003, 07:18 »
Or even boot from the XP CD and delete the existing partition using the partition manager tool in the setup process.
You can then add a new partition and format it from the same tool ;)
Offline ketamininja
« Reply #5 on: November 19, 2003, 13:43 »
Hmmm...
What OS are you using... XP I presume!
Are you trying to format another hard drive other than the C drive? If you are trying to format the C drive, you can't do it from Windows because Windows is using that drive!
