Author Topic: Help, It`s Took Over my Homepage  (Read 4558 times)
Offline spooner
« on: November 21, 2003, 08:55 »
Hi , let me know if you can help me out.
Everytime i open internet explorer, something has latched itself onto my home page, so instead of google i get different porn sites  :o.
tried going into tools , internet options and changing back to google but it just reverts back.
be grateful if anybody can help.
ps. i`m running windows xp
thanks
spooner
sed all my sick, t`morra i`m ringing in dead !
Re:Help, It`s Took Over my Homepage
« Reply #1 on: November 21, 2003, 09:11 »
Hi!
You've been hijacked.
What you need to do is download software like Spybot S+D from
security.kolla.de.
Download.
Install.
Run.
Check for online updates - there will be some.
Download the updates.
CLOSE ALL INTERNET EXPLORER WINDOWS
Scan for hijackers using spybot
Wait a bit :)
Select fix the selected items.
After doing that you may need to reboot and scan again.
Best bet would then be to download all the updates for your version of windows and also download and run Hijack this from tomcoyote.org/hjt/, sellect the scan option, copy to clipboard and post the results here :)
Oh and :welcome:
« Reply #2 on: November 21, 2003, 09:47 »
I would also suggest that you download a small program called StartPageGuard which will prevent your home page from being hijacked again.
http://www.webattack.com/get/startpageguard.shtml
Offline spooner
« Reply #3 on: November 21, 2003, 11:53 »
Thanks chaps,will do this tonight and let u know how i get on  ;)
« Reply #4 on: November 21, 2003, 14:25 »
If you choose the Immunize function in Spybot S&D you can achieve the same result as Clive's StartPageGuard and never have to worry about hijacking home page again. :)
It is worth pointing out that you need to click "Online", then "Search for Updates" to find out if there are any updated spyware signiture updates available.
« Reply #5 on: November 21, 2003, 22:28 »
A quick question about Spybot (not that I intend to download it - a combination of AdAware and Spyware Blaster seems to do the trick for me) but is it true that Spybot and AdAware on the same PC can cause compatability problems?
« Reply #6 on: November 21, 2003, 22:35 »
I've not noticed any probs yet, and they've co-existed quite happily for absolutely donkey's now, Dave.  Recommend you do it.   :)
« Reply #7 on: November 21, 2003, 23:07 »
I use both as well, without any problems.  Spybot and Ad Aware each sometimes find things the other misses,  which is why I use both.  Paranoid?  Me?  :peep:
Offline Michelle
    • Techieminx
« Reply #8 on: November 21, 2003, 23:30 »
I have both too .... probably cos Simon or sandra told me to get them both, and I don't think I have any more problems than I did before :lol:
« Reply #9 on: November 22, 2003, 00:26 »
Don't listen to her, she's blonde.   :-[
« Reply #10 on: November 22, 2003, 00:39 »
OK, I've been convinced.  I'll give it a try.
Thanks, folks.  :)
Offline spooner
« Reply #11 on: November 22, 2003, 12:56 »
ok guys,
these are the results of the scan, i can see the obvious ones, sex this sex that, but there must be other liddle rascals moochin about in there,
let me know if any ideas
cheers
Logfile of HijackThis v1.97.7
Scan saved at 12:35:23, on 22/11/2003
Platform: Windows XP  (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 (6.00.2600.0000)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\System32\sistray.EXE
C:\WINDOWS\System32\khooker.exe
C:\WINDOWS\System32\SiSAudUt.exe
C:\Program Files\Common Files\Real\Update_OB\realsched.exe
C:\Program Files\Trend Micro\PC-cillin 2002\pccguide.exe
C:\Program Files\Trend Micro\PC-cillin 2002\PCCClient.exe
C:\Program Files\Trend Micro\PC-cillin 2002\Pop3trap.exe
C:\WINDOWS\System32\ctfmon.exe
C:\Program Files\Messenger\msmsgs.exe
C:\WINDOWS\System32\shellexp.exe
C:\PROGRA~1\INCRED~1\bin\IMAPP.EXE
C:\WINDOWS\System32\devldr32.exe
C:\Program Files\Trend Micro\PC-cillin 2002\Tmntsrv.exe
C:\Program Files\Trend Micro\PC-cillin 2002\PCCPFW.exe
C:\WINDOWS\System32\wuauclt.exe
C:\Program Files\Spybot - Search & Destroy 1.1\SpybotSD.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\Program Files\WinRAR\WinRAR.exe
C:\DOCUME~1\Simon\LOCALS~1\Temp\Rar$EX00.734\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://ie-search.com/srchasst.html (obfuscated)
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://ie-search.com/home.html (obfuscated)
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.co.uk/
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://xwebsearch.biz/
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://ie-search.com/home.html (obfuscated)
R1 - HKCU\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://ie-search.com/srchasst.html (obfuscated)
R1 - HKCU\Software\Microsoft\Internet Explorer\Search,CustomizeSearch = http://ie-search.com/srchasst.html (obfuscated)
R1 - HKLM\Software\Microsoft\Internet Explorer,SearchURL = http:///
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.co.uk/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://ie-search.com/srchasst.html (obfuscated)
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://ie-search.com/home.html (obfuscated)
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://ie-search.com/home.html (obfuscated)
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://ie-search.com/home.html (obfuscated)
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch = http://ie-search.com/srchasst.html (obfuscated)
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://ie-search.com/srchasst.html (obfuscated)
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Microsoft Internet Explorer provided by blueyonder
R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://ie-search.com/home.html (obfuscated)
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = http=webcache.blueyonder.co.uk:8080
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,HomeOldSP = http://66.250.57.28/
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,SearchAssistant = http://ie-search.com/srchasst.html (obfuscated)
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,SearchAssistant = http://ie-search.com/srchasst.html (obfuscated)
R1 - HKCU\Software\Microsoft\Internet Explorer,SearchAssistant = http://www.sharempeg.com/find/
R1 - HKCU\Software\Microsoft\Internet Explorer,CustomizeSearch = http://www.sharempeg.com/find/
R1 - HKLM\Software\Microsoft\Internet Explorer\Search,(Default) = http://ie-search.com/srchasst.html (obfuscated)
F2 - REG:system.ini: UserInit=C:\WINDOWS\System32\userinit.exe,C:\WINDOWS\System32\svcpack.exe
O1 - Hosts: 198.65.164.168 00hq.com
O1 - Hosts: 198.65.164.168 8ad.com
O1 - Hosts: 198.65.164.168 searchv.com
O1 - Hosts: 198.65.164.168 www.searchv.com
O1 - Hosts: 198.65.164.168 008k.com
O1 - Hosts: 198.65.164.168 www.008k.com
O1 - Hosts: 198.65.164.168 hotbookmark.com
O1 - Hosts: 198.65.164.168 www.hotbookmark.com
O1 - Hosts: 198.65.164.168 700k.com
O1 - Hosts: 198.65.164.168 www.700k.com
O1 - Hosts: 198.65.164.168 xsex.ws
O1 - Hosts: 198.65.164.168 www.xsex.ws
O1 - Hosts: 198.65.164.168 7days.ws
O1 - Hosts: 198.65.164.168 www.7days.ws
O1 - Hosts: 198.65.164.168 onlysex.ws
O1 - Hosts: 198.65.164.168 www.onlysex.ws
O1 - Hosts: 198.65.164.168 opsex.com
O1 - Hosts: 198.65.164.168 www.opsex.com
O1 - Hosts: 198.65.164.168 yellow500.com
O1 - Hosts: 198.65.164.168 www.yellow500.com
O1 - Hosts: 198.65.164.168 thesten.com
O1 - Hosts: 198.65.164.168 www.thesten.com
O2 - BHO: (no name) - {02478D28-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Common\ycomp5_0_2_6.dll
O2 - BHO: (no name) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 5.0\Reader\ActiveX\AcroIEHelper.ocx
O2 - BHO: HTML Source Editor - {086AE192-23A6-48D6-96EC-715F53797E85} - C:\WINDOWS\System32\DReplace.dll
O2 - BHO: (no name) - {1F48AA48-C53A-4E21-85E7-AC7CC6B5FFB1} - C:\WINDOWS\msccnc.dll
O2 - BHO: (no name) - {41353F8B-78CE-48A5-BE44-153ED293D192} - C:\PROGRA~1\POPUPP~1\PopLib.dll
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1.1\SDHelper.dll
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
O3 - Toolbar: &Yahoo! Companion - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Common\ycomp5_0_2_6.dll
O4 - HKLM\..\Run: [SiS Tray] C:\WINDOWS\System32\sistray.EXE
O4 - HKLM\..\Run: [SiS KHooker] C:\WINDOWS\System32\khooker.exe
O4 - HKLM\..\Run: [SiS7012Utility] C:\WINDOWS\System32\SiSAudUt.exe -wdm
O4 - HKLM\..\Run: [NeroCheck] C:\WINDOWS\System32\NeroCheck.exe
O4 - HKLM\..\Run: [IncrediMail] C:\PROGRA~1\INCRED~1\bin\IncMail.exe /c
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -osboot
O4 - HKLM\..\Run: [WinApp32] msapp.exe
O4 - HKLM\..\Run: [Windows Shell Library Loader] load shell.dll /c /set -- by windows setup --
O4 - HKLM\..\Run: [pccguide.exe] "C:\Program Files\Trend Micro\PC-cillin 2002\pccguide.exe"
O4 - HKLM\..\Run: [PCCClient.exe] "C:\Program Files\Trend Micro\PC-cillin 2002\PCCClient.exe"
O4 - HKLM\..\Run: [Pop3trap.exe] "C:\Program Files\Trend Micro\PC-cillin 2002\Pop3trap.exe"
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\ctfmon.exe
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKCU\..\Run: [IncrediMail] C:\PROGRA~1\INCRED~1\bin\IncMail.exe /c
O4 - HKCU\..\Run: [Yahoo! Pager] C:\Program Files\Yahoo!\Messenger\ypager.exe -quiet
O4 - HKCU\..\Run: [Tracks Eraser Pro] C:\Program Files\Acesoft\Tracks Eraser Pro\te.exe min
O4 - HKCU\..\Run: [Explorer] C:\WINDOWS\System32\shellexp.exe en
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Restrictions present
O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O8 - Extra context menu item: &Add animation to IncrediMail Style Box - C:\PROGRA~1\INCRED~1\bin\resources\WebMenuImg.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
O8 - Extra context menu item: Web Search - c:\windows\ex.htm
O9 - Extra button: PopupPopper Control Panel (HKLM)
O9 - Extra button: Messenger (HKLM)
O9 - Extra 'Tools' menuitem: Yahoo! Messenger (HKLM)
O9 - Extra 'Tools' menuitem: Windows Messenger (HKLM)
O12 - Plugin for .mpeg: C:\Program Files\Internet Explorer\PLUGINS\npqtplugin3.dll
O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
O12 - Plugin for .tmp: C:\Program Files\Internet Explorer\PLUGINS\npqtplugin2.dll
O16 - DPF: {02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} - http://www.apple.com/qtactivex/qtplugin.cab
O16 - DPF: {0E5F0222-96B9-11D3-8997-00104BD12D94} (sys Class) - http://www.pcpitstop.com/pcpitstop/PCPitStop.CAB
O16 - DPF: {166B1BCA-3F9C-11CF-8075-444553540000} (Shockwave ActiveX Control) - http://download.macromedia.com/pub/shockwave/cabs/director/swdir.cab
O16 - DPF: {2B323CD9-50E3-11D3-9466-00A0C9700498} - http://us.chat1.yimg.com/us.yimg.com/i/chat/applet/v43/yacscom.cab
O16 - DPF: {30528230-99F7-4BB4-88D8-FA1D4F56A2AB} (YInstStarter Class) - http://download.yahoo.com/dl/installs/yinst.cab
O16 - DPF: {41F17733-B041-4099-A042-B518BB6A408C} - http://apple.speedera.net/qtinstall.info.apple.com/borris/us/win/QuickTimeInstaller.exe
O16 - DPF: {7D1E9C49-BD6A-11D3-87A8-009027A35D73} - http://chat.yahoo.com/cab/yacsui.cab
O16 - DPF: {9F637568-E5F7-4CB2-BD01-818CF6C561F9} (PhotosCtrlUK Class) - http://uk.photos.yahoo.com/ocx/uk/yexplorer1_9uk.cab
O16 - DPF: {A17E30C4-A9BA-11D4-8673-60DB54C10000} (YahooYMailTo Class) - http://us.dl1.yimg.com/download.yahoo.com/dl/installs/yse/ymmapi.dll
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
« Reply #12 on: November 22, 2003, 13:18 »
Looks like you've got a varient of Coolwebsearch infecting you.
Download and run:
http://www.spywareinfo.com/~merijn/files/cwshredder.zip
And this should fix it.
Offline Michelle
    • Techieminx
« Reply #13 on: November 22, 2003, 13:19 »
Hi spooner,
I'm sure Dack will be able to tell you the answer to that one, he helped me get rid of the right ones. Although some did tell me there was a help thing on that programme that you can go into and ask. But I never got round to that.
good luck
« Reply #14 on: November 22, 2003, 13:29 »
Don't know about most of that stuff, but if you download and run Ad Aware, and SpyBot, they should hopefully be able to remove anything nasty for you.  You could also download and run a trial version of Anti Trojan.  See how you get on with that lot!  I'm sure one of our techies will be able to go through your other results in more detail.
