Author Topic: folder browser in delphi  (Read 2227 times)
Offline measter
« on: November 22, 2003, 20:01 »
how would i bring up
in delphi 7
Current CPU Info
Re:folder browser in delphi
« Reply #1 on: November 23, 2003, 00:16 »
Pretty straightforward IIRC - (haven't used Delphi/kylix for a while, more of a C++ guy these days).
Example code here:
http://www.delphibasics.co.uk/RTL.asp?Name=TOpenDialog
Comes down to calling the standard OpenDialog and SaveDialog components.
Offline measter
« Reply #2 on: November 23, 2003, 00:27 »
ok, thanks
Current CPU Info
Offline measter
ini files in delphi
« Reply #3 on: November 24, 2003, 07:08 »
is there an easy way of writing to ini files in delphi or do i have to do it the hard way
Current CPU Info
Re:ini files in delphi
« Reply #4 on: November 24, 2003, 12:49 »
I dont think that any form of coding has an easy way Measter  ???
