Author Topic: Back Up  (Read 1032 times)
Offline arthurb
Back Up
« on: November 23, 2003, 17:54 »
I have recently downloaded lots of windows updates from the web. How can I create a back up disk of my XP Pro SP1 OS with the recent upgrades so that I won't need to download them again should I have to re-load the OS?
Re:Back Up
« Reply #1 on: November 24, 2003, 07:17 »
AFAIK, you will have to wait for Service Pack 2 before you can do that ArthurB. The service packs have a mechanism that allows you to integrate their files into a folder containing the original XP CD files. You can then burn the resultant folder to another CD.
Offline ketamininja
Re:Back Up
« Reply #2 on: November 25, 2003, 13:28 »
You could create an IMAGE of the HDD (or partition).
Norton GHOST or PQMagic will allow you to do this.
Go to the SYMANTEC website and check out ghost.
