Author Topic: Web pages not loading fully  (Read 860 times)
Offline owes01
  • New Registration
« on: November 23, 2003, 21:19 »
Why does any page I visit on the Web have an x where a photograph should be.  I can only view the photo if I right click on it and select "show picture".
In IE I have checked the Tools - Internet Options - Advanced - Multimedia tabs and checked the "show pictures" check box, but still nothing.
I have a Compaq PC with a P2 266 processor loaded with Windows Millenium and have had no problems until now.
Any help would be greatly appreciated
Thanks
Re:Web pages not loading fully
« Reply #1 on: November 23, 2003, 21:28 »
Hiya owes01,
 :welcome:  Try this if you're using MS Internet Explorer.
From the browser menu, select Tools -> Internet Options.  Click on the 'Advanced' tab and scroll down to the 'Multimedia' section then tick the box next to 'Show pictures'.
If that doesn't work, we'll just have to wait for a grown-up to appear.   ;)
« Reply #2 on: November 23, 2003, 22:06 »
Hi owes01,
It might be worth un-ticking that box, then close and restart Internet Explorer, and re-tick the same box.
If that doesn't work, maybe an overlay re-installation of IE (i.e. re-install it on top of itself), might help.  If you do decide to do an overlay re-installation, although your Favorites should be OK, it might be best to back them up first, just to be sure they are safe.
« Reply #3 on: November 23, 2003, 22:13 »
Whooops!  I must remember not to type and telephone at the same time.   ::)
