Author Topic: computer freezes when playing games  (Read 818 times)
Offline supadupa
« on: November 24, 2003, 14:53 »
I have AMD xp 1700 with 780mb ram and geforce 4 ti4200 with onboard soundcard and windows XP. This happens with almost evry game i play when in game computer freezes, monitor goes black for few moments there is some sound from game than it goes quiet and i can't return to windows only thing i can do is to turn off computer. Always it is a matter of time before this happens i rearly normaly quit game because of this. This was happening even before i changed my graphic card. Can anyone help please?
Online Simon
Re:computer freezes when playing games
« Reply #1 on: November 24, 2003, 17:23 »
How's your CPU cooling?  Do you have a decent heat sink and fan?  I was just wondering, in my infinate ignorance, if your AMD 1700 XP is finding it a bit tough going these days, and maybe getting overwarm, and cutting out?
You may be advised to wait for further advice from one of our proper techies, as I have been known to take wild stabs in the dark!    ;)
Offline supadupa
« Reply #2 on: November 24, 2003, 23:00 »
Thanks for replaying that could be answer cpu works at 60 C or more i think i should do something about that. Another question what are normal temperature for my CPU
« Reply #3 on: November 24, 2003, 23:20 »
60 is certainly on the high side.  It should run much lower than that.  I understand that this is a common problem with that particular chip.  I believe it can be cured by updating the BIOS.
« Reply #4 on: November 24, 2003, 23:44 »
I wouldnt have thought that 60 was excessively high for an AMD, and you cant cure it with updating the bios as far as I know Clive, only by fitting a bigger heat sink, fan or extra case fans etc.
There is a setting in the bios to shut the pc down at specified temperatures and it may be set at 55, I think I have mine at 75 but I havent looked for a long time  :)
