Author Topic: Cd Writer Freezing  (Read 1102 times)
Offline Robotochan
Cd Writer Freezing
« on: November 30, 2003, 20:31 »
When I try to write a CD any CD, my CD writer opens about 17% through the writing process but nothing is written onto it. Then the motors don't work and the light stays on and windows keep trying to read from it  >:(
b]Oxymoron: [/b]
Example:
Microsoft Works
Re:Cd Writer Freezing
« Reply #1 on: November 30, 2003, 20:45 »
I have had this problem Robo, just couple of days ago. What caused it was installing additional burning programmes. Some burning software is incompatible with others while some leave stray files on your system after you have uninstalled them. I eventually had to uninstall my orginal software as installing the others had completely made it unworkable. With a little help form a friend who we shall call S, I managed to get an up to date package of my software which was easycd creator. :D
« Reply #2 on: November 30, 2003, 20:48 »
Whats Simon been doing now then  :o
« Reply #3 on: November 30, 2003, 20:54 »
 ;D ;D ;D I should have said, a female friend whom we shall call S!!!!! ;)
« Reply #4 on: November 30, 2003, 21:22 »
You mean Serenity??   :o
Offline Michelle
    • Techieminx
« Reply #5 on: November 30, 2003, 22:56 »
ohh does someone have some gossip for me  :P
Offline Robotochan
« Reply #6 on: December 01, 2003, 17:33 »
Cheers Lona  ;D I'm actually about to format my PC due to a worm that cannot be moved inefection most of my exe files  :)
b]Oxymoron: [/b]
Example:
Microsoft Works
