November 27, 2024, 16:50
Technical Help & Discussion
IDE Connections
Topic: IDE Connections (Read 1583 times)
IDE Connections
December 01, 2003, 16:19 »
I have three drives (DVDROM, DVDRW, and CDRW), plus my hard drive, which has used up all my IDE connections. What happens if I want to install a second hard drive, but I have no IDE connections left?
TR
Re:IDE Connections
December 01, 2003, 17:20 »
Show off
Tony
Loyal Member
Re:IDE Connections
December 01, 2003, 20:29 »
A Raid Mobo I should think, but surely you could ditch the DVD-Rom. I mean how many DVD's do you wanna play at once, you Southern Softie Show off
Plus then you could Sell your old one cheap to Hooky, and then he would also be happy, did you keep the box
TR
Re:IDE Connections
December 01, 2003, 21:06 »
Ahh but my friend or is that fiend Tony
, I have all that Simon has, but
ALL
his works where mine doesnt
Re:IDE Connections
December 01, 2003, 21:13 »
Buy a PCI RAID card like I did for my 3 hard drives, CDROM and CDRW.
Cost me about £15 IIRC.
Sandra
Ultimate Member
Re:IDE Connections
December 01, 2003, 22:52 »
Do you not run short of IRQs then Adept, or does the ones on the PCI raid card share them with the the PCI bus or something
Re:IDE Connections
December 02, 2003, 07:30 »
According to Windows Device Manager, it uses a shared IRQ along with my soundcard and some other cards.
Dack
Established Member
Re:IDE Connections
December 02, 2003, 21:59 »
http://www.sudhian.com/showfaqs.cfm?fid=15&fcid=26
For a basic explanation of PCI interrupt steering under ACPI.
lobo
Full Member
Re:IDE Connections
December 12, 2003, 21:35 »
Fit a PCI IDE card and that will give you you 4 more IDE connections
Brian
Homer , The Odyssey, line 1
IDE Connections
