Author Topic: usbport.sys  (Read 2589 times)
Offline measter
usbport.sys
« on: December 03, 2003, 20:40 »
this came up when i was starting my pc and now it won't start up
Code: [Select]
a problem has been detected and windows has been shut down to prevent damage to your computer.<br /><br />DRIVER_IRQL_NOT_LESS_OR_EQUAL<br /><br />if this is the first time you've seen this stop screen, restart your computer. if this screen appears again, follow thses steps.<br /><br />check to make sure any new hardware or software is properly installed. if this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.<br /><br />if problems continue, disable or remove any newly installed hardware or software. disable BIOS memory options such as caching or shadowing.if you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode.<br /><br />Technicle Information:<br /><br />*** STOP: 0x000000D1 (OxE283FE56, 0x00000002, 0x00000000, 0xF98F6D7E)<br /><br />*** USBPORT.SYS - Adress F98FD7E base at F98EF000, DateStamp 3DBDDC31
my specs:
amd athlon 1200+ xp
256 ddr sdram 266 mhz
40 gb maxtor 7200 rpm
6 usb(2 front, 4 back)
ati radeon 9600 pro 256 ddr 400 mhz
Current CPU Info
Re:usbport.sys
« Reply #1 on: December 03, 2003, 22:05 »
Can you unplug any usb devices that you arent going to need for the initial startup Measter ?
See if that cures it.
It appears to be having a problem loading one of the drivers.
Does it start up ok in safe mode, with or without the usb devices attached ?
Offline measter
Re:usbport.sys
« Reply #2 on: December 03, 2003, 22:10 »
i'll just go up and try that
[edit]
i tried that and it came up that &lt;some path i can't remember&gt;\system32(i think)\system is missing or corrupt. and that to enter the windows cd and to repair. i put it in and done what it said. then it asked to put in a command in at the command promte(c:\windows) so i put in fixboot and it came up:
Code: [Select]
a problem has been detected and windows has been shut down to prevent damage to your computer.<br /><br />DRIVER_IRQL_NOT_LESS_OR_EQUAL<br /><br />if this is the first time you've seen this stop screen, restart your computer. if this screen appears again, follow thses steps.<br /><br />check to make sure any new hardware or software is properly installed. if this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.<br /><br />if problems continue, disable or remove any newly installed hardware or software. disable BIOS memory options such as caching or shadowing.if you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode.<br /><br />Technicle Information:<br /><br />*** STOP: 0x0000000A (0x88351296, 0x00000002, 0x00000000, 0x8018E583
Current CPU Info
Offline measter
Re:usbport.sys
« Reply #3 on: December 04, 2003, 14:59 »
i'v just disconnected everything from the usb ports, and it worked untill i tried to get to the partition screen. at that point it came up what looks like the same error as before. last time this happened i had to format the computer, and that was about 2 months ago :wtf:
Current CPU Info
Re:usbport.sys
« Reply #4 on: December 04, 2003, 18:28 »
Sounds like a problem with your IDE dribers then Measter.
Do you know what motherboard you have?
Offline measter
Re:usbport.sys
« Reply #5 on: December 04, 2003, 18:45 »
no, a cpu repair shop replaced it when my old one got fried somehow :( apparently it was because of the way teh ide cables were plugged in but the first way we plugged them in was the same way they were plugged in when we got it from the repair shop
Current CPU Info
Re:usbport.sys
« Reply #6 on: December 04, 2003, 19:45 »
If you install a program like Si Soft Sandra, Aida or Belarc Advisor, then that should identify your motherboard and alow us to be able to tell you where to get the latest drivers from.
Did it get into safe mode fully or have you not tried that yet ?
Offline measter
Re:usbport.sys
« Reply #7 on: December 04, 2003, 20:10 »
well, it wouldn't let me boot before because a file called system was missing or corrupt. but i tried fixboot again and it did finish and booted uo. still nothing about the usb drivers yet but i'll run berlac advisor
i still can't believe it booted *cue usbport.sys error*
Current CPU Info
Offline measter
Re:usbport.sys
« Reply #8 on: December 04, 2003, 20:21 »
Operating System:
Windows XP Home Edition Service Pack 1 (build 2600)
Processor:
1.67 gigahertz AMD Athlon XP
128 kilobyte primary memory cache
256 kilobyte secondary memory cache
Drives:
41.10 Gigabytes Usable Hard Drive Capacity
24.53 Gigabytes Hard Drive Free Space
SONY CD-RW CRX225E [CD-ROM drive]
3.5&quot; format removeable media [Floppy drive]
Maxtor 6E040L0 [Hard drive] (41.11 GB) -- drive 0, s/n E178P6LE, rev NAR61590, SMART Status: Healthy
Controllers:
Standard floppy disk controller
Primary IDE Channel [Controller]
Secondary IDE Channel [Controller]
VIA Bus Master IDE Controller
Bus Adapters:
Standard Enhanced PCI to USB Host Controller
VIA Rev 5 or later USB Universal Host Controller
Communications:
Realtek RTL8139 Family PCI Fast Ethernet NIC
VIA Compatable Fast Ethernet Adapter
Network Card MAC Address: 02:30:BD:27:B9:A6
Network IP Address: ***.***.***.*** / 24
System Model:
No details available(duh!)
Main Circuit Board:
Board: K7VT2 2.00
Bus Clock: 133 megahertz
BIOS: American Megatrends Inc. P1.20 12/10/2002
Memory Modules:
256 Megabytes Installed Memory
Slot '0' has 256 MB
Slot '1' is Empty
Slot '2' is Empty
Slot '3' is Empty
Local Drive Volumes:
c: (on drive 0)    41.10 GB    24.53 GB free
Display:
RADEON 9600 SERIES [Display adapter]
RADEON 9600 SERIES - Secondary [Display adapter]
Nissei Sangyo L5AK5 [Monitor] (14.9&quot;vis, s/n LCD0987654321, April 2003)
Multimedia:
Standard Game Port
VIA AC'97 Enhanced Audio Controller (WDM)
Other Devices:
USB Human Interface Device
Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
HID-compliant mouse
USB Root Hub
USB Root Hub
USB Root Hub
USB Root Hub
i'm gonna make a page with that info on it and upload it
[edit] heh, forgot some stuff
Current CPU Info
Re:usbport.sys
« Reply #9 on: December 04, 2003, 20:41 »
Well, I would take a wild guess that this is your motherboard.   ;D
http://www.asrock.com.tw/product/product_k7vt2.htm
Offline measter
Re:usbport.sys
« Reply #10 on: December 04, 2003, 20:42 »
thats definatly it. i got a clear view of the thing right here :lol:
also, if anyone wants to know my current cpu specs it's in my sig ;D
Current CPU Info
Offline lobo
    • http://www.burnleywood.com
Re:usbport.sys
« Reply #11 on: December 04, 2003, 23:28 »
System has recovered from a serious error
DRIVER_IRQL_NOT_LESS_OR_EQUAL.
This problem can be caused by:
1. A damaged Virtual Memory Manager Page file.
2. A faulty RAM (memory) module.
3. A RAM module that is NOT compatible with the computers chip set.
If the RAM is OK or changing it does NOT fix the problem:
01. Right-click My Computer and press Properties.
02. Select the Advanced tab.
03. Press the Settings button under Performance.
04. Select the Advanced tab.
05. Press the Change button under Virtual memory.
06. Select No paging file and press the Set button. Press Yes if prompted.
07. Press OK, OK, and OK.
08. Shutdown and restart your computer.
09. Right-click My Computer and press Properties.
10. Select the Advanced tab.
11. Press the Settings button under Performance.
12. Select the Advanced tab.
13. Press the Change button under Virtual memory.
14. Select System Managed size and press the Set button. Press Yes if prompted.
15. Press OK, OK, and OK.
16. Shutdown and restart your computer.
Enjoy
Brian :P
Homer   , The Odyssey, line 1
