Author Topic: slow internet  (Read 3543 times)
Offline adamdaly
    • http://www.btinternet.com/~adamdaly
slow internet
« on: December 07, 2003, 03:00 »
i've been suffering a slow connection for some time. i find that i sent a MB than i receive, like right now i got 1.5MB while i sent 10MB. any ideas what is causing this. i phone a helpdesk and they told me to reinstall windows, but this is a brand new comp. also when i check the windows task manager the svchost.exe is on it 4 times ans uses up a lot of ram. is this normal. i have run spybot and deleted all files that it says could cause my problem.
any ideas
adamdaly
f i can't be a good example, i'll just have to be a horrible warning.
Re:slow internet
« Reply #1 on: December 07, 2003, 09:46 »
Hi Adam,
I'm sure someone will be able to help you with this, but can you just confirm, is this 56K dial up, or broadband we're talking about?
Offline adamdaly
Re:slow internet
« Reply #2 on: December 07, 2003, 16:02 »
its a 56k dial up.
adamdaly
Re:slow internet
« Reply #3 on: December 07, 2003, 17:13 »
Sorry Adam, but I'm a bit confused, especially by this part:
Are you saying you tried to send something of 10Mb over 56K?   :o
Re:slow internet
« Reply #4 on: December 07, 2003, 17:15 »
So what you are saying is that you can upload files quicker than you can download? ??? Sorry I'm not clear what you mean. Telling you to re-install Windows is a standard helpdesk trick to get you off their back when they don't have a solution for you ;)
svchost is a process which allows dll files to be executed. It is perfectly normal to have more than one svchost process at a time :)
Re:slow internet
« Reply #5 on: December 07, 2003, 17:17 »
Is this an e mail attachmnet or just what the current modem log is showing has been transmitted/received  ???
Re:slow internet
« Reply #6 on: December 07, 2003, 17:28 »
Adamdaly can you bring up a box like the picture below.
Offline adamdaly
Re:slow internet
« Reply #7 on: December 07, 2003, 17:30 »
sorry, what i mean is that over the course of an internet session my computer logs that i have received 1.5MB whereas i have set 10mb. looking at the small icon on the bottom right, there seems to be a constantly out going info, but i don't know from what source.
adamdaly
Re:slow internet
« Reply #8 on: December 07, 2003, 17:36 »
Do you have firewall software installed Adam?
If so, perhaps you could remove everything from the list of programs allowed to connect to the Internet. You can then re-enable them one at a time as they ask for access. It may help you track down which program causes a surge in activity.
Offline adamdaly
Re:slow internet
« Reply #9 on: December 07, 2003, 17:44 »
yup its firewalled but i can't find any way of changing its properties.
Re:slow internet
« Reply #10 on: December 07, 2003, 17:52 »
Do you know which firewall software you use? And while you are at it could you tell us a bit about your PC? Operating System, Memory, processor etc. :)
Offline adamdaly
Re:slow internet
« Reply #11 on: December 07, 2003, 18:00 »
i'm using XP home edition, the computer has 512MB RAM and has a P4 2.8 Processor. Don't know about the firewall software. it just says that it is firewalled beside the icon in the network connections  window.
adamdaly
Re:slow internet
« Reply #12 on: December 07, 2003, 18:13 »
Right click the properties and select About and that should tell you which it is  :)
Re:slow internet
« Reply #13 on: December 07, 2003, 19:14 »
Ah, I see. XP's firewall :-\. The good news is that you are firewalled, but the bad news is it is for incoming connections only. With this type of firewall a trojan can install itself onto your PC and you wouldn't know it.
Do you have anti-virus software installed? If so make sure that it is up-to-date. If not go heer and download one of the free ones now. While you are at it, look here and get yourself a decent firewall too. The jury is out on which is best. Many people find ZoneAlarm OK and others have problems with it. Sygate is another good one.
Offline adamdaly
Re:slow internet
« Reply #14 on: December 07, 2003, 19:40 »
yeah i have norman av, i've been trying to up-grade it but the connection keeps dropping with their server.
adamdaly
