Author Topic: Router Log - IP Spoofing  (Read 2232 times)
Offline DJ
« on: December 08, 2003, 21:50 »
Hi All,
I have a wireless internet setup and every night my lovely Netgear DG824M wireless modem and router sends me a log by email.  Usually they are something like...
Sun, 2003-12-07 19:19:01 - UDP packet dropped - Source:xxx.xxx.xx.xxx
,1030 WAN - Destination:xx.xxx.xxx.xx.xxx LAN - [Inbound Default rule match]
replicated over and over again.
(Where xx are ip addresses)
But tonight i got an alert that looks like this:
2003-12-08 22:30:31 - IP Spoofing - Source:xxx.xxx.xxx.xxx
,0,LAN - Destination:xxx.xxx.xxx.xxx,0,WAN
What does 'IP Spoofing' mean, are there an actions I should take and what can I do to prevent it.  ???
Whilst I'm on about these netgear logs - are there any programs available to analyse them - usually I just put them in an email folder - but it would be handy if I knew what they mean  ::)
Thanks all again,
DJ
Re:Router Log - IP Spoofing
« Reply #1 on: December 08, 2003, 22:07 »
IP spoofing is a method of attacking a network in order to gain unauthorized access.
But dont ask me how to stop it... ???
A technique used to gain unauthorized access to computers, whereby the intruder sends messages to a computer with an IP address indicating that the message is coming from a trusted host. To engage in IP spoofing, a hacker must first use a variety of techniques to find an IP address of a trusted host and then modify the packet headers so that it appears that the packets are coming from that host.
« Reply #2 on: December 09, 2003, 07:09 »
I wouldn't worry about it too much DJ. The log file comes from the Netgear's built-in firewall. It is telling you that it has detected a particular form of attack and blocked it.
Have a look at http://www.securityfocus.com/infocus/1674 for a (slightly technical) explanation of IP Spoofing :)
Offline DJ
« Reply #3 on: December 09, 2003, 10:13 »
Ok - Thanks all.
I won't worry about it then - glad the firewalls doing its job.
DJ
Offline DJ
« Reply #4 on: December 27, 2003, 18:31 »
Still getting these IP Spoofing messages nearly every day now - all with the same IP address.
If I add the IP address to my banned list on my router - would it have any bad effects? Also would I add it to the outbound or inbound list?
Thanks
DJ
« Reply #5 on: December 27, 2003, 23:10 »
Only if you need to connect to something which happens to be on that IP address. Is it the same address every time DJ or a range? If is one IP, I would complain about it to your ISP's abuse department.
Offline DJ
« Reply #6 on: December 28, 2003, 11:59 »
:thanks: Adept :adept:
Yes it's the same IP address every time the alert looks like the following:
Code: [Select]
<br />2003-12-08 22:30:31 - IP Spoofing - Source:<br />xxx.xxx.xxx.xxx,0,LAN - Destination:yyy.yyy.yyy.yyy,0,WAN<br />
the xxx &amp; yyy are the ip address which are always the same.
I think an email to my ISP is in order - I'll do that today.
Ta  ;)
DJ
« Reply #7 on: December 28, 2003, 16:16 »
PM me the IP address would you? I'll do some &quot;research&quot; :)
Offline DJ
« Reply #8 on: December 28, 2003, 16:44 »
I emailed my ISP and got the following response...
Dear customer - 169.x is an address which is assigned by windows to the local machine if it cannot detect a hdcp assigned address properly and so you would in effect be banning your own machine. Thanks.
I didn't realise this about 169.xxx  ::)
Still don't know why its happening though - adept you have a PM  :P
DJ
« Reply #9 on: December 28, 2003, 16:57 »
Yes, they are right DJ :)
The 169.254.xxx.xxx address range is a local one that Windows XP uses when it cannot get a &quot;proper&quot; address using DHCP. So the IP spoofing is coming from your own PC ::)
I know it's annoying, but I wouldn't worry about it :)
Offline DJ
« Reply #10 on: December 28, 2003, 17:12 »
:doh: Oh well - nevermind.
Just off to do 100 lines.
I must stop spoofing myself
 :o  ;)  :P
Thanks again :adept:
DJ
« Reply #11 on: December 28, 2003, 17:13 »
If you don't you'll go blind ;)  :hatoff: :waving:
Offline DJ
« Reply #12 on: January 06, 2004, 18:30 »
Hi again Adept :waving:
Been getting these Spoofing alerts now coming from 239.254.xxx.xxx
Am I still ok to ignore these or is there something dodgy going on?  :-\
DJ
« Reply #13 on: January 06, 2004, 19:35 »
Hi DJ :waving: back at you :)
I'm sure it's OK for you to ignore these - they are an indication that your router is doing its job properly :)
Offline DJ
« Reply #14 on: January 06, 2004, 20:13 »
Cheers Adept. :wave: :banana:
Just thought I'd make sure.
DJ  ;)
edit - cos eye kant spel.
