Author Topic: annoying bug  (Read 4587 times)
Offline labopp
annoying bug
« on: December 09, 2003, 16:38 »
i am having a problem with my xp. everytime i open up a window whether it's a file window or a window in explorer for instance, i get this message popping up: " is not a valid date. and it has the title explorer or iexplore when i am in explorer.
i cant seem to find the issue. thanx for any help.
a.
Re:annoying bug
« Reply #1 on: December 09, 2003, 16:53 »
Hi Labopp, and
This might sound blindingly obvious, but have you checked the date on your system clock?  If you're not sure how to do this, right click the clock in the bottom right hand corner of your screen, select "Adjust Date / Time", and it's pretty self explanatory from there on.
If that's not the problem, come back to us, as we will probably need some more details to help you further.
Offline labopp
Re:annoying bug
« Reply #2 on: December 09, 2003, 18:51 »
hi simon.
yes i have checked the clock and this is not it. everything is fine with it. i dont understand.... heellppp....
Offline Serenity
Re:annoying bug
« Reply #3 on: December 09, 2003, 19:07 »
Hi Labopp   :welcome:  hope the techies here manage to help with your PC problem, then stick around and join in the fun on our forum  ;)
Re:annoying bug
« Reply #4 on: December 09, 2003, 19:09 »
Have you installed or uninstalled anything just prior to this happening ?
Have you updated your AV and run a scan ?
Can you restore your OS back to when it was ok if you have installed something ?
Re:annoying bug
« Reply #5 on: December 09, 2003, 19:09 »
Can you tell us the exact error message, word for word, Labopp, or better still, are you able to do a screenshot and post it on here as an attachment?   Hopefully one of the techies will be able to help you then.
Offline Michelle
    • Techieminx
Re:annoying bug
« Reply #6 on: December 10, 2003, 08:18 »
I did a little search and there are alot of problems with this (ON XP AND 2000) and this is the fix that seems to be on most of them ?
Am not techie and have no idea if you have tried this or why it would change if it was okay before ? ............but here you are ........
 A. This is due to the Short Date Style in the Regional Settings of your computer being different to the default setting (normally set to dd/MM/yyyy hence the error).
OK so how do you change it?
- Go to the Control Panel and Double Click 'Regional Settings'
- Click on the Date Tab
- Now look under 'Short Date' you will see an option labelled 'Short Date Style'
- Select the date format 'dd/MM/yyyy'
- Apply and OK
Re:annoying bug
« Reply #7 on: December 10, 2003, 12:35 »
Better still install "Tclock" everything is at the click of right button including 12 month calender  ;)and easy pz set up.
Hookstar
Re:annoying bug
« Reply #8 on: December 10, 2003, 16:50 »
Better Still, dump XP ;D ;D ;D
Offline Michelle
    • Techieminx
Re:annoying bug
« Reply #9 on: December 10, 2003, 16:58 »
:funny: :clap:
Nice one lona  ;)
Re:annoying bug
« Reply #10 on: December 10, 2003, 18:30 »
Don't listen to Lona, she's old and set in her ways!    Hope Michelle's answer works for you, Labopp.  It's got to be something to do with the time and date settings.
Re:annoying bug
« Reply #11 on: December 10, 2003, 18:42 »
Not nice Simon..Lona may be set in her ways but old, she looks the same age as you  :P when you had hair  8)
Edit: must remember to proof read before posting..(must be getting old here )  >:(
Re:annoying bug
« Reply #12 on: December 10, 2003, 19:08 »
Well I would'nt stand for that Kojack....Tellim Savalas  Simon  ;D
Re:annoying bug
« Reply #13 on: December 10, 2003, 19:12 »
That reminds me, Hooky, we were promised a pic of YOU!   ;) :P ;D ;D
Tony, we're going to send you a big wooden spoon for Christmas!   ;D ;D
Offline Michelle
    • Techieminx
Re:annoying bug
« Reply #14 on: December 10, 2003, 23:04 »
if poor labopp ever comes back for his answer he's gonna wonder what you lot are on about ! :lol:
but I agree with simon
 :o
where is this pic hookie ?  Or were you the fisherman that bev posted recently. :pmsl:
hmmm tony does like to stir the pot a bit doesn't he  ;D
