April 17, 2025, 01:27
Technical Help & Discussion
Wont Eject
Topic: Wont Eject (Read 10024 times)
TR
Wont Eject
November 05, 2002, 07:38 »
Small problem for the techies and a frustrating one for me.
On my liteon cd rewriter (40x12x48)when I use incd to copy files, when I have finished it wont eject on the front button I have to delve in the control panel, any ideas would be greatly received.
Hook 8)star
An afterthought!! with no disk no problem after burning, problem.
Corky
Regular Member
Re:Wont Eject
November 05, 2002, 13:00 »
Usually after burning, an alert should appear telling you that the cd burn has been done correctly, after clicking ok, the cd draw should eject on its own. I haven't used InCD, but that happens with every other burn software i have used.
Corky
img]http://www.raid-designs.co.uk/emote/corkypc.gif[/img]
TR
Re:Wont Eject
November 05, 2002, 13:09 »
Corky
it works like that with Nero, but when I copy word files to disk I have have to go int a file to eject.
Hope that makes sense
Re:Wont Eject
November 05, 2002, 13:37 »
I don't use Nero myself Hook, but on all the installations I've done for other people, In-CD has behaved like this for me too.
Perhaps thats just the way it works
TR
Re:Wont Eject
November 05, 2002, 17:35 »
Cheers,St Adept
Corky
Regular Member
Re:Wont Eject
November 05, 2002, 17:56 »
Im currently using WinOnCD 3.8 It isn't free, but it is a great program for burning cd's.. I think there is a free trial, if you want to test it out.
http://www.roxio.com
Corky
Sandra
Ultimate Member
Re:Wont Eject
November 05, 2002, 18:15 »
Have you got an English version of Win On Corky ?
I aquired the full one
But it is in German
and I didnt think they had released an English one yet
Corky
Regular Member
Re:Wont Eject
November 05, 2002, 18:16 »
the setup on this one was in german, but the program is english... Weird that
Sandra
Ultimate Member
Re:Wont Eject
November 05, 2002, 18:22 »
Ah that would explain it,I just remembered that when I tried to install it,for some reason possibly my PC, my PC crashes and I have had to uninstall it.So if I had managed to run it fully it would probably be ok
Vorschprung Durch Technic,Nicht Wahr
Corky
Regular Member
Re:Wont Eject
Reply #9 on:
November 05, 2002, 18:32 »
heres the english version.
http://www.pcw.co.uk/Products/Software/1133279
i think
Sandra
Ultimate Member
Re:Wont Eject
Reply #10 on:
November 05, 2002, 19:00 »
OOOOOH! Thats a lot dearer than mine cost
But I think it explains why my PC crashes when I try to install it :-
Minimum requirements: Pentium 400MHz PC; Windows 98/XP; 64Mb Ram; 300Mb hard disk space (2Gb for full VCD authoring facilities); CD or DVD burner.
Definitely dont have 2 gig of free space and I am only running a 450.So presumably it doesnt like my specifications
Re:Wont Eject
Reply #11 on:
November 05, 2002, 19:10 »
Dunno where I picked up this bit of info now, but I'm given to understand that it's not a brilliant idea to have two different CD burning programs on your system at the same time, as they can get a bit stroppy with each other. Anyone else heard of this phenomenon?
TR
Re:Wont Eject
Reply #12 on:
November 05, 2002, 19:16 »
Sandra/
couldn't copy your last pic but near enough
vorsprung durch technik Verbesserung.
Anyway Im happy with nero and its not that I copy many files to cd and I never burn
CD's so its not a great problem.
Hook
Sandra
Ultimate Member
Re:Wont Eject
Reply #13 on:
November 05, 2002, 19:19 »
I have heard of that exact thing Rodders,but I have a few friends who have a few progs on and seem to do ok with it.
With mine I usually use Nero or DiscJuggler and as long as I just Burn CDs and do nothing else usually I am ok.
If I am on line or doing something off line it doesnt seem to like it but I think thats down to lack of processing power in my old PC
Sandra
Ultimate Member
Re:Wont Eject
Reply #14 on:
November 05, 2002, 19:21 »
But Hook you've turned me from a Bitch into a Fozzie bear :'(
Wont Eject
