Author Topic: Bios Agent  (Read 1032 times)
Bios Agent
« on: December 21, 2003, 10:59 »
This is a handy little app to determine the brand and version of your BIOS in case you need to flash, or get technical data for reasons of tweaking. Check it out Here
This information is very helpful in the event you need or want to upgrade the BIOS and other components on your PC. The BIOS Agent program is totally harmless, will not damage your system in any way, and no hidden information about your system is submitted to a database without your prior knowledge first. It is simply a tool which you can use to obtain useful information about your system.
