Author Topic: DVD recorders  (Read 15699 times)
Re:DVD recorders
« Reply #45 on: December 29, 2003, 17:58 »
Does it come with a sheet to cover it up with Sandra?   :P ;D ;D
I believe my Pioneer DVR-3100 will be fine for what I want, and I will be mainly using DVD-RW discs, so that I can watch them back on my other machine, while I'm recording new programmes, much as I use my three VCRs at the moment.  Only problem is, I could really do with 2 DVDRs, for when two things are on different channels at the same time.  Will definitely be waiting for a price reduction before buying another one though!
Re:DVD recorders
« Reply #46 on: December 29, 2003, 18:03 »
Typical male  ::)
Do you not realise that its not always the best looking things that are the best to have.
Functionality, durability and practicality are more than skin deep you know  :P :P :P
Re:DVD recorders
« Reply #47 on: December 29, 2003, 18:36 »
The term 'durability' may be a little optimistic Sandra.  After all, as it's only just come out, how do we know how long it will last?!   ;) ;D ;D
Re:DVD recorders
« Reply #48 on: December 29, 2003, 19:00 »
Kiss have been around quite a few years and I think they are German so that means they are quality in my book  :)
Re:DVD recorders
« Reply #49 on: December 29, 2003, 19:45 »
Also attributes of the volkswagen Beetle - still doesn't mean I'd buy one :)
