Author Topic: power off  (Read 1414 times)
Offline jon996
power off
« on: December 29, 2003, 23:50 »
wen i click on Start -> Turn off Computer none of the buttons work!!!!! so  i cant turn off  >:(
rive it like you stole it!
Re:power off
« Reply #1 on: December 30, 2003, 00:03 »
Has this just happened today Jon ?
Offline jon996
Re:power off
« Reply #2 on: December 30, 2003, 00:05 »
and yesterday but i thought that if i  jus switched it off it would b fine, but it isnt :(
Re:power off
« Reply #3 on: December 30, 2003, 00:08 »
Is it since you cleared the CMOS and loaded BIOS defaults ?
Offline jon996
Re:power off
« Reply #4 on: December 30, 2003, 00:11 »
i dnt no....maybe i jus dont no
Re:power off
« Reply #5 on: December 30, 2003, 00:12 »
Cant think of a Bios setting that would have that effect but it may be worth having a look  ???
Re:power off
« Reply #6 on: December 30, 2003, 00:14 »
This happened to me, but I'm buggered if I can remember the solution!   Hang on... it'll come to me...
Offline jon996
Re:power off
« Reply #7 on: December 30, 2003, 00:16 »
i have started using regsupreme....but it wouldnt delete a key that turns off my pc
Re:power off
« Reply #8 on: December 30, 2003, 00:53 »
This is so going to annoy me!  What was happening with mine was (and this was about 18 months ago), I would hit Start > Turn Off Computer > Shutdown, the Shutdown box would disappear, and I would be back to my desktop like nothing had happened.  No reboot, just nothing.
I'm fairly sure it was something simple to rectify, but I think the answer was on the 'old' forum.  Maybe one of the ExPC people might remember?
It seems odd that this has only just started to happen, Jon.  Just a shot in the dark, but, assuming you are using XP, have you thought about doing a System Restore to before the problem began?
Offline jon996
Re:power off
« Reply #9 on: December 30, 2003, 00:58 »
no theres nothing there, but im goin  2 reinstall tweakui power tool, see if that sheds ne light on the matter :)
Offline jon996
Re:power off
« Reply #10 on: December 30, 2003, 01:03 »
now the standby button works but no others :brick:
Offline princeofdarkness
Re:power off
« Reply #11 on: January 17, 2004, 23:27 »
i have no idea  ??? but i hope u get it sorted  ;)
quot;Spirits damned to rot
Eyes of the dead
Broken glass reflections
Show your flesh eaten away
