Author Topic: Deep Burner "Free"  (Read 1263 times)
Deep Burner "Free"
« on: December 31, 2003, 13:40 »
Just stumbled across this Site, dont know how good it is but might be worth a look to those that burn a lot
DeepBurner - perfect CD/DVD burning solution for FREE
DeepBurner is a new CD/DVD burning software that utilize power and effeciency. With DeepBurner you can create data, bootable, and audio CDs as well as data DVDs. Friendly and intuitive user interface with drag-and-drop features helps in all aspects: starting from compilation of data and audio to be burn onto a CD/DVD till making and printing labels for the particular type of media storage.
Hookstar
Re:Deep Burner "Free"
« Reply #1 on: December 31, 2003, 14:28 »
Could be useful.  I wonder if it contains spyware?
« Reply #2 on: December 31, 2003, 17:07 »
Well I have been cop backing up my DVDs this afternoon seems very very easy and all seems ok, had some little niggles but that could do with the mirror discs that I had bundled with the dvd driver.
I keep checking with the Adaware and spybot and nothing untowards with spyware.
Hookstar
« Reply #3 on: December 31, 2003, 18:50 »
Downloaded, but not installed yet.  I'll certainly give it a try.   :)
