Author Topic: How would you rate my pc?  (Read 2507 times)
Offline a.rowe55
« on: January 02, 2004, 20:35 »
Operating System     Microsoft® Windows® XP Home Edition
Processor     Intel® Celeron 2.60GHz
Cache     128Kb
Processor socket type     MPGA 478B
Motherboard chipset     SiS 651
Bus speed     400MHz
AGP Slot (total / free)     1/1
PCI Slot (total / free)     3/2
Memory
Installed memory     256MB DDR
Total RAM slots     2
Maximum memory     1GB
Hard Drive     80GB
Rotation speed (trs / mn)     5400rpm
Floppy drive
Internal or external     Internal
CD-RW / DVD-RW
CD or DVD type     DVD & CDRW
Graphics     64MB (Shared) SiS 651GX 3D Graphics SDR/DDR
Integrated on motherboard or on AGP Slot     Integrated
Sound
Chipset     Sigmatel STAC9750T
Integrated on motherboard or on PCI slot     Integrated
Modem     56Kps CNR
USB Port     2x front, 2x rear V2.0
Ports     1 Serial, 1 Parallel
VGA external monitor port     1
Audio line in     1
Microphone line in     1
Headphone line out     1
Keyboard / Pointing device
Pointing device     PS2 Mouse
Keyboard     PS2 Keyboard
Network Ethernet RJ45     Yes
1     Storm Speakers
Offline Robotochan
Re:How would you rate my pc?
« Reply #1 on: January 02, 2004, 22:08 »
7/10 where 10 is the best  ;) The celeron ain't the best, could do with more RAM and a new GFX card. Just my opinion as I'm a gamer  :)
b]Oxymoron: [/b]
Example:
Microsoft Works
« Reply #2 on: January 03, 2004, 00:03 »
Depends what you use it for m8.  I only use my PC for word processing, one spreadsheet, running Encyclopedia Britannica Multimedia Edition, and three or four hours a day at the very most on the internet.  My Pentium 450, 128MB RAM and total of 6GB Hard Drive Space, is more than adequate for me.
« Reply #3 on: January 03, 2004, 00:10 »
In the land of the blind, a one eyed man is a king  ;)
Offline greenking
« Reply #4 on: January 03, 2004, 01:24 »
In the land of the blind, a one eyed man is a Greenking  ;)
Sandra you say the nicest things   :-*
« Reply #5 on: January 03, 2004, 14:25 »
Nothing wrong with that system, now I'll take a guess, it was bought  somewhere like PC World, Curry's or Comet. It's made by a big volume box shifter.
Celeron is Intels budget chip designed for basic needs computing see here it costs £72 better to have gone the AMD XP2600+ route at £68 see here
In the memory department it is upgradable to 1GB memory capacity, however the cheap skate maker has put 256KB memory in it instead of a 512KB  memory module. So you either dump your paid for 256Kb or settle for a max 768Kb upgrade, instead of just adding another 512kb module to make 1GB.
Plus the cheap skate maker is using 64KB of your 256KB memory by using onboard graphics. Better systems have seperate graphics cards, latest Motherboards have 8xAGP. Another pointer to a cheap system is the fact that it only has three PCI expansion slots, and one of those is taken up with your modem, so really you only have two.
Is it a DVD/CD-RW combo not seperate drives? another cheapskate way of keeping costs down. And last but not least it is a 5400rpm Hard Drive as against the norm being the 7200rpm drives......
Having said that, I bet loads of people would love to have that system..............I hope you do not think bad of me....but you did ask  ::) ;)
« Reply #6 on: January 03, 2004, 15:07 »
Now now Tony, why should "a.rowe55" think of you any differently to the rest of us, we all think badly of you  :P
Offline Camstop
« Reply #7 on: January 03, 2004, 15:38 »
a.rowe55 you could commission "The chuckle brothers inc" to build you a new one.  8)
There a bit rough about the edges but their hearts in the right place and you wont get any unwelcome hairs in your case if they assemble it in their southern branch.. :slightlymad: ;) ;D
« Reply #8 on: January 03, 2004, 16:01 »
The lessons that cause one angst are usually the lessons that will best serve you in the future. I merely assumed A rowe was seeking honest opinion, so I gave it   ;D and besides I have a characture to portray and maintain on this board  ;)
Better to be known for straight talking, than for being two faced and patronising. But I know you my little liebfraumilch  know and love me as ever  :-*  ;)
Cammy you are awefull.....but I like you  ;)
« Reply #9 on: January 03, 2004, 18:42 »
I would also regretfully add that if it only has 3 PCI slots, there's a good chance that it doesn't have an AGP slot for a decent graphics card.  Another cost cutting shortcut.   :(
« Reply #10 on: January 04, 2004, 00:51 »
It has  ;D
Offline princeofdarkness
« Reply #11 on: April 12, 2004, 20:44 »
5/10 with 10 being the highest mainly becoz of processor,3 pci slots isnt much,ram+maximum ram aloud (1 gig aint much)and graphics card with me being quite a gamer  :-\
PoD
quot;Spirits damned to rot
Eyes of the dead
Broken glass reflections
Show your flesh eaten away
