Author Topic: Door to CD drive  (Read 1494 times)
Offline Pwilsonscott
Door to CD drive
« on: January 03, 2004, 18:29 »
The doorto my CD drive was open and i accidently knocked it, and it would not close with the button, and was stiff to close with my hand. I managed to get it closed but now it will not open.
I feel really stupid, can you advise me what to do ?
Many thanks
Re:Door to CD drive
« Reply #1 on: January 03, 2004, 18:38 »
Sounds like you've knocked it off it's carriage, PWS.  I'm not sure if there's a way to repair it - it seems there should be, but I'm not going to sit here and advise you to take it to bits!   :o
Re:Door to CD drive
« Reply #2 on: January 03, 2004, 18:46 »
Funny, I was just going to do exactly that Simon :D
It does sound as if the drive tray has been knocked off its rails :( Your only alternative, if you want to fix the drive, is to take it apart, but be aware that if you do you will probably need to buy a new one afterwards ;) :-\
Re:Door to CD drive
« Reply #3 on: January 03, 2004, 19:03 »
You know what I'm like with hardware, Sean  :horror:   ;) ;D ;D
Offline Camstop
Re:Door to CD drive
« Reply #4 on: January 03, 2004, 22:38 »
Chuckle, chuckle..>> ;) :-X ;D
Re:Door to CD drive
« Reply #5 on: January 04, 2004, 00:58 »
Shaddup cammy  ;) ;D I've done the same
have you tried the strightened paper clip in that tiny hole on the face of the CD drive [thats what it is there for] I knocked a CD extended drive of its carrage, it was off kilter, straightened it up and shut it [just like you] would not open, did the paper clip thingy which opened it and worked by the button hence forth. Sort of a few full stops missing POD, but I doubt you would be bothered  ;D ;)
Re:Door to CD drive
« Reply #6 on: January 04, 2004, 01:26 »
Are you still drunk from the new years celebrations Tony  ::)
Its Pwilsonscott not PoD  ;D ;D ;D
Re:Door to CD drive
« Reply #7 on: January 04, 2004, 01:51 »
SODS LAW, PWS.
Nothing you can do  about it, sh1t happens, and reading this forum over the last week, Sods Law has got you hook-line-and-sinker.
Seriously though, I have done several CD Drives in over the last few years.  Very little you can do about it.  Tony's suggestion is about as positive as you will find.
Re:Door to CD drive
« Reply #8 on: January 04, 2004, 19:43 »
DOH !!
Re:Door to CD drive
« Reply #9 on: January 04, 2004, 20:39 »
I gently prized the front of the drawer off, pulled out the disc holder, re-aligned it, clipped the front back on and it opens and closes just fine. i was concerned the drive itself might be damaged but it seems OK. Thanks
Re:Door to CD drive
« Reply #10 on: January 04, 2004, 21:08 »
:welldone:  PWS.  Probably not the textbook method, but at least you got it sorted!   ;D ;D
Re:Door to CD drive
« Reply #11 on: January 04, 2004, 21:17 »
There's a textbook method? ??? :o :-\
Re:Door to CD drive
« Reply #12 on: January 04, 2004, 21:47 »
You're asking me??   ;) ;D ;D
Offline dcys02647
Re:Door to CD drive
« Reply #13 on: January 04, 2004, 22:19 »
A happy ending @ last  ;D  I think "s**t or bust" is the phrase. Nice 1 for not just chucking it & buying another from p c world.   ;D ;D ;D ;D
You are right chorleydave !.  How he escaped sods law I will never know, I don't :(
Re:Door to CD drive
« Reply #14 on: January 04, 2004, 23:04 »
Does no one know what a hammer's for any more?   ::)
