This explains what its all about below
When you use Windows XP's "Hide Inactive Icons" feature, to hide in frequently used icons in the System Tray, XP will sometimes display them, even though they shouldn't be. And sometimes it will not display an icon when it should. This program allows you to reset the usage information.
Usage: Download xp_pastitems.vbs and save this file to your hard drive. Locate the VBS file you and double click it. A confirmation dialog will appear when the script is done.
This utility is only intended for Windows® XP. You may need Administrator level access to use this utility. If you do not have Administrator level access, the program will say it is finished, but will not have made any changes.
This page last updated 09/15/2003 00:24
All material © Doug Knox
Cure it here
