Author Topic: Windows XP time running fast  (Read 1333 times)
Offline knight
« on: January 05, 2004, 15:11 »
Do people have a solution for this weird problem:
once every week I have to re-set the time settings on my computer because it is running 5 minutes or so fast!
In stead of manually changing settings I can also use the "Update Now" button of the automatic time server update in Windows XP. So nothing wrong with the automatic update proces...
Anyone got a clue?
Cheers!
J.
Offline Serenity
Re:Windows XP time running fast
« Reply #1 on: January 05, 2004, 15:18 »
Hello Knight and  :welcome: Im afraid I am unable to help you with this particular query but one of our regular "Techies" will be along shortly to assist you  :D
« Reply #2 on: January 05, 2004, 15:21 »
Hiya Knight,
I use this free prog, it can be set to auto check/update your clock as often as you want [mine is set to once per day] I'm on W2K Pro and as XP is just a tarted up version of W2K Pro it will work fine on your setup http://www.rocketsoftware.com/portfolio/rockettime/upgrade.htm
Offline knight
« Reply #3 on: January 05, 2004, 16:01 »
Program looks OK! Solves the problem indeed... though the problem in itself gives me the creeps...
If someone could indicate a possible cause of the problem: thanks!!
K.
« Reply #4 on: January 05, 2004, 16:39 »
Not sure if this isn't stating the bleeding obvious, but if you right click your clock, go to 'Adjust Date/Time', you get the clock setting screen.  One of the tabs should be 'Internet Time' (see below), which allows you to synchonise with a time server, and that should keep the time accurate for you.  It does on mine, anyway.   :)
Offline knight
« Reply #5 on: January 05, 2004, 19:10 »
Yap that is bleeding obvious, so I didn't fall for that one ;-) Of course the automatic update is on. Frequency of update process is however not high enough to prevent a irritating time difference (its running fast) of up to 10 minutes in a few days.
Maybe Mobo is just whacko (its the MS-6570 with the nVidea nForce2 chipset)?
K.
« Reply #6 on: January 05, 2004, 19:21 »
Might be worth simply changing your CMOS battery as it will be that keeping the clock running when the system is powered down.
Anyway you are only getting a 1 second in 2016 seconds error :)
