Author Topic: Formatting my c drive  (Read 985 times)
Offline spooner
« on: January 06, 2004, 16:37 »
Hope this is in the right section. ???
Need to format my hard drive as my pc is slowing up, have done it before but that was when i was on win 98.
i`m now on xp, can anybody talk me through it.
thanks in advance  ;)
sed all my sick, t`morra i`m ringing in dead !
Re:Formatting my c drive
« Reply #1 on: January 06, 2004, 17:17 »
Do you mean, you want to save your data and such, and then reformat and reinstall XP ?
Offline spooner
« Reply #2 on: January 06, 2004, 18:26 »
Yes
« Reply #3 on: January 06, 2004, 18:44 »
It is in the wrong bit, I will move it after I answer you  :)
Have you already got what you need saved on CD  ?
If so just either use a 98 boot disk and boot into dos then type Format C: or, change the boot sequence to boot from the CD and let it format the drive before you re install XP  :)
