Author Topic: Shutting down/logging off  (Read 1351 times)
Offline Aaron
« on: January 06, 2004, 23:05 »
I have a minor but very very annoying problem.  My computer refuses to turn off.  If you turn off using start-turn off/restart or log off nothing happens.  If however you switch users to get back to the log on screen the shut down/restart facility work.  I would really like a solution because its getting annoying. Thanks!  I have windows xp pro sp1 fully updated
Re:Shutting down/logging off
« Reply #1 on: January 07, 2004, 00:29 »
Could be LOTS of things. Worth having a look here and trying some of the suggestions.
http://aumha.org/win5/a/shtdwnxp.php
