Author Topic: Acronis TrueImage  (Read 1394 times)
Offline JK
Acronis TrueImage
« on: January 18, 2004, 21:14 »
Hi
Could you please help me with a problem. I tried to use the
software to backup my system. When running, after a short while
it stops the backup with an error message, saying that a program
is still running. I have turned off the anti virus and firewall
and checked that a program is not running. The only thing that
I can think of is my PCI ADSL modem, that is always looking
for a connection. Any help would be appreicated.
Offline DJ
Re:Acronis TrueImage
« Reply #1 on: January 18, 2004, 21:32 »
Hi JK and :welcome:
Can you tell us which software you are using to backup and what are you backing up onto (CD, ZIP ?)
Also what operating system are you using (Windows 98 / XP etc).
Then someone should be able to help  ;)
:thanks:
DJ
Offline JK
« Reply #2 on: January 18, 2004, 22:24 »
Hi
Trying to use Acronis TrueImage.
PC running windows ME. All works fine until the software
stops with error message that a program is still running.
« Reply #3 on: January 18, 2004, 22:28 »
There is a free program called End It All, which does just that.  It closes all running programs.  Might be of some use, JK.
Also might be worth doing a virus scan and an adware / spyware scan, especially if you think something might be running in the background you are unaware of.  Ad Aware, and / or Spybot, are what we usually recommend to seek and remove spyware.
Does it say, or give any clue, as to what is still running?
Offline JK
« Reply #4 on: January 18, 2004, 22:30 »
Have no adware or spyware running.
Think that its the ADSL modem always running.
« Reply #5 on: January 18, 2004, 22:41 »
OK, well you seem to have got it sussed, so let us know how you get on.   :)
