Author Topic: MPR.dll  (Read 802 times)
MPR.dll
« on: January 18, 2004, 23:16 »
I can't open windows media player for some reason. I get a message that it is not installed properly and do I want to re-install. I click yes, re-installed and I am still getting the same message. I also cannot open windows messenger as I get the same message. I have checked and the MPR.Dll file is still on my system, so what could be causing this?
Online Simon
Re:MPR.dll
« Reply #1 on: January 18, 2004, 23:29 »
Have you tried uninstalling first, then reinstalling, Lona?
Re:MPR.dll
« Reply #2 on: January 19, 2004, 07:16 »
Can you tell us the exact error message please Lona?
Re:MPR.dll
« Reply #3 on: January 20, 2004, 21:10 »
Don't know what caused it but I went into Norton Utilites and it sorted whatever was causing the problem. :)
