Author Topic: Software for CDs on Harddisk  (Read 961 times)
Offline jg
« on: January 22, 2004, 22:13 »
Hi All,
Can someone suggest a good piece of software for taking an audio CD and converting it to mp3's that I can put on my harddisk?
Thanks,
JG
Re:Software for CDs on Harddisk
« Reply #1 on: January 22, 2004, 22:41 »
I havent tried it but theres a free program on here called FreeRip, it may be what you are looking for  :)
http://www.MGShareware.com
« Reply #2 on: January 23, 2004, 00:27 »
A good one is CDEX - connects to the internet music database to get the track naems for you too.
http://www.cdex.n3.net/
« Reply #3 on: January 23, 2004, 07:42 »
There's loads of them here:
http://www.mp3-converter.com/mp3_converter_freeware.htm
I use Audio Crusher, which says it only works with 95/98, but I use it without any problems with XP.
