Author Topic: Adding Ram  (Read 1494 times)
Adding Ram
« on: January 23, 2004, 21:43 »
I have been checking various sites with a view to purchasing 256 sdram 133mhz 168pin unbuffered dimm and find there is a vast difference in prices. I have heard that there is quality ram and not so good  Does anybody have any advice on this matter.? :)
Re:Adding Ram
« Reply #1 on: January 23, 2004, 23:18 »
My advice would always be to use Crucial.com, Lona.  They are not always the absolute cheapest, but you can guarantee quality and compatability.
Re:Adding Ram
« Reply #2 on: January 23, 2004, 23:24 »
I'm glad you said that, Simon, as that's the very one I was considering buying from.
http://www.crucial.com/uk/store/MPartspecs.Asp?mtbpoid=C8DC2F91A5CA7304&WSMD=Pavilion+7890&WSPN=CT209163
Re:Adding Ram
« Reply #3 on: January 23, 2004, 23:35 »
Lona, although I havnt checked out your link to the full, have you tried ebuyer.com >>> http://www.ebuyer.com/customer/products/index.html?action=c2hvd3N1YmNhdGVnb3J5X3BhZ2U=&subcat_uid=547
Hookstar  :-*
Re:Adding Ram
« Reply #4 on: January 23, 2004, 23:45 »
I would go with Crucial too if buying on line.
If buying locally, where they would let you take it back and try a different one then it may be worth saving a few pounds, otherwise I would say Crucial everytime  :)
Offline princeofdarkness
Re:Adding Ram
« Reply #5 on: January 24, 2004, 21:11 »
crucial is undoubtably the best  ;)
PoD
quot;Spirits damned to rot
Eyes of the dead
Broken glass reflections
Show your flesh eaten away
