Author Topic: How big is your Pe !!!!!!  (Read 1824 times)
« on: January 24, 2004, 15:09 »
rsonal memory, right now I have got your attention ;D
Can anybody remember who posted a link to a site where there was a downloadable tool for disabling Epson printer cartrige monitoring? I read somewhere, that the built in cartrige monitoring cut down the prints per cartridge by around 25%
I thought it was either lobo or Dack, but I could be wrong
Re:How big is your P!!!!!!!!!!
« Reply #1 on: January 24, 2004, 15:18 »
Hi Tony  ;D
Just been reading about that on another forum and the jury is out on if it works or not?
http://www.amazon.co.uk/exec/obidos/ASIN/B00006BCCI/ref=ase_onthewebcom-21/202-7511268-1332650
I read a magazine test report and it turns out that despite common sense, you don't notice a loss of quality even with quite high ink saving settings. Some printers work better than others. I can't remember where i read it, but it was within the past month.
Offline Robotochan
« Reply #2 on: January 24, 2004, 15:32 »
I think it was lobo, Tony  :)
http://pc-pals.com/index.php?board=33;action=display;threadid=5291
While your still deciding to use it or not try Ink Saver and put it on 20%. Looks bout the same as normal but saves 20% of the ink  ;D
b]Oxymoron: [/b]
Example:
Microsoft Works
Offline greenking
« Reply #3 on: January 24, 2004, 15:38 »
 :pmsl:  Worked though  ;D
« Reply #4 on: January 24, 2004, 15:52 »
Tony, why don't you just disable it in Monitoring Preferences?  That's what I did, and now I don't get informed until the ink actually runs out and it stops printing.
« Reply #5 on: January 24, 2004, 16:01 »
It never fails GK, and it is a tossup [no pun intended]regards who read it first, it was either Shell or Hooky  :o
Thanks lads you all did me proud, Robo I did a search on Lobo and zilch came up  ???
« Reply #6 on: January 24, 2004, 16:21 »
http://pc-pals.com/index.php?board=33;action=display;threadid=6712
as well - looks like we both linked to the same site :)
« Reply #7 on: January 24, 2004, 17:57 »
As usual ::) I was right yet again ;)
However after installing it, I just keep getting an error message....."printer off, or some other problem"  Looked up the help files [Sandra would be proud of me} it suggests disabling Epson Status Monitor. Which I have, by stopping it loading at startup, but still no joy. Bugger, it looked a handy bit of kit and all.     :'(
Offline Michelle
    • Techieminx
« Reply #8 on: January 24, 2004, 23:14 »
oi I resemble that remark!!!  ;) ::) :P ;D
