Author Topic: screen  (Read 787 times)
Offline computer_whizz
    • http://www.geocities.com/makz_tabs
screen
« on: January 25, 2004, 22:00 »
hi, when i turn my computer on my screen goes slightly pink. does anyone know why this happens or how i can stop it?
thanks
 may be left handed but im always right
Re:screen
« Reply #1 on: January 25, 2004, 22:04 »
Has this only just started happening ?
Which OS are you using ?
Maybe if you drop the refresh or try different ones that may help.
Does it correct itself after its been running for a few minutes or does it stay with a pink tint ?
Welcome aboard by the way   :)
Re:screen
« Reply #2 on: January 25, 2004, 22:37 »
This happened to a friend of mine only theirs had a green tint.    Turned out to be a bad connection with the monitor lead -- might be worth checking it out.
Offline DJ
Re:screen
« Reply #3 on: January 26, 2004, 09:26 »
Has happened to me in the past - use the degaus button (I think thats how to spell it!) - usually the button, or onscreen menu is of a magnet - this makes your monitor judder for one second then all will be fine.
Hope that helps
DJ
