Author Topic: screen problem  (Read 2743 times)
Offline princeofdarkness
screen problem
« on: January 26, 2004, 17:49 »
i was on woms armageddon and it was fine but after i installed the latest beta patch which worked on my old pc the whole screen isnt there
i would put in an screenshot but im not sure how have you got any ideas?
quot;Spirits damned to rot
Eyes of the dead
Broken glass reflections
Show your flesh eaten away
Re:screen problem
« Reply #1 on: January 26, 2004, 18:07 »
Use the Attach: feature in the reply part PoD, and just browse to the screenshot that you have saved on your pc  :)
Re:screen problem
« Reply #2 on: January 26, 2004, 18:14 »
i just tried to paste the screenshot n it just comes up black lets just say it doesnt have the whole screen but i have a patch now and i need to install it extract it into directory but i dont no where that is do u?
Eyes of the dead
Re:screen problem
« Reply #3 on: January 26, 2004, 18:16 »
If you have a shortcut to it on your dektop just click on FIND TARGET and it will open the directory where the exe is installed, just copy and paste the patch in there PoD  :)
Re:screen problem
« Reply #4 on: January 26, 2004, 18:20 »
patch worked but it aint changed the screen because all the options are in the bottom right hand corner of the screen so icant get to most of them :-[
Eyes of the dead
Re:screen problem
« Reply #5 on: January 26, 2004, 18:23 »
Can you try altering the screen resolution to a higher one ?
This will make your icons smaller but will possibly allow them all to be accessible  :)
Re:screen problem
« Reply #6 on: January 26, 2004, 18:29 »
didnt work it doesnt affect the game
Eyes of the dead
Re:screen problem
« Reply #7 on: January 26, 2004, 18:56 »
Sorry PoD, its not a game that I am familiar with so I dont think I can help you any more on this one  ???
Maybe Robo or one of the other younger members will know more about it  :)
Re:screen problem
« Reply #8 on: April 13, 2004, 16:35 »
found a patch for it  ;)
PoD (jonah)
Eyes of the dead
