November 27, 2024, 13:07
Technical Help & Discussion
PC temps :/
Topic: PC temps :/ (Read 3219 times)
Dominic
Regular Member
PC temps :/
January 27, 2004, 20:15 »
My cpu temp use to be around 40, but that was before i placed both sides back on, and put it back under my desk, but for sum reason now its gone up to 63! my PC temp still remains 25-27, any ideas?
Re:PC temps :/
January 27, 2004, 20:26 »
Check your CPU fan. It sounds as if it may have slowed down or even maybe stopped altogether. Is it noisier than usual ?
Dominic
Regular Member
Re:PC temps :/
January 27, 2004, 20:39 »
Nope it's going at 4600 rpm
Dominic
Regular Member
Re:PC temps :/
January 27, 2004, 20:40 »
What voltage should a 2000+ be on? maybe thats the reason.
TR
Re:PC temps :/
January 27, 2004, 20:45 »
I find with my CPU temp as it goes up after a period of time. I clean out the fins of the cooling unit on the CPU...and it seems to work as the temp goes down about 6 to 8 c .
Hookstar
Re:PC temps :/
January 27, 2004, 20:46 »
You should be able to find all the specs you need
here
Maximum temp. on a 2000+ is 90 deg. so 63 deg. isn't so bad.
Dominic
Regular Member
Re:PC temps :/
January 27, 2004, 20:57 »
Says 2000+ fsb is 233? i thought mine was 133, or do they do them in 133? plus my vcore is 1.77 and that site says 1.75, would that make any difference?
Dack
Established Member
Re:PC temps :/
January 27, 2004, 21:06 »
Speed is clock doubled - 133MHz = 266 FSB, 166MHz = 333FSB, 200 MHz = 400FSB
Sounds like you have got an airflow problem in that although the fan is spinning it cannot get enough air to cool it down. Check to see if your fans are blowing the correct way and not fighting against each other.
Dominic
Regular Member
Re:PC temps :/
January 27, 2004, 21:10 »
thx.. and what about the vcore?
Dack
Established Member
Re:PC temps :/
Reply #9 on:
January 27, 2004, 21:39 »
a 1% difference could simply be down to the motherboard reading being slightly off.
Dominic
Regular Member
Re:PC temps :/
Reply #10 on:
January 27, 2004, 23:31 »
So changing the cpu vcore from default (1.77) to what this cpu recommended core is 1.75 wont cool it down ? to be honust i think its the s**tty retail fan, and i might need sum new thermal paste as i moved the cpu chip a while back to a new mobo.
agua-moose
Regular Member
Re:PC temps :/
Reply #11 on:
January 27, 2004, 23:52 »
plus or minus 0.02 of a volt is not going to affect it in the slightest. it is perfectly normal for it to be out by that amount.
e rock hard so you don't have to, you lazy non-rocking piece of poo.
Dominic
Regular Member
Re:PC temps :/
Reply #12 on:
January 28, 2004, 00:05 »
agh, thought not, just trying to thing what could of made the cpu temp go up, could a new hdd disk do this?
Dack
Established Member
Re:PC temps :/
Reply #13 on:
January 28, 2004, 08:36 »
If a bigger drive then almost certainly it would be adding more heat to the system - what temperature do you get when the side of the case is off? If it's less then you've simply got an airflow problem.
Dominic
Regular Member
Re:PC temps :/
Reply #14 on:
January 28, 2004, 11:18 »
It goes to round about 51 - 54.
PC temps :/
