Author Topic: Keyboard Problem  (Read 830 times)
Offline twiggy
Keyboard Problem
« on: January 30, 2004, 15:17 »
When pressing certain keys on my keyboard it shows the wrong key's. Is there any way of configering it so when i press a key it actaul shows what i press? im running windows xp.
thanks mark
Re:Keyboard Problem
« Reply #1 on: January 30, 2004, 15:58 »
Which keys are wrong Mark ?
Is it the " and @ the wrong way round ?
If so then you have got your keyboard set as a US english keyboard not UK english one.
Just go into Control Panel, Regional and language Options, Languages then Details and remove the US one and Add the UK one.
It will say you cant remove the US one as its in use but will be removed on next restart.
Just reboot and things should be ok :doggie:
Re:Keyboard Problem
« Reply #2 on: January 30, 2004, 18:05 »
I have an idea!   :-X ;D ;D
(Sorry Mark, that was an 'in joke'.)   ;) ;D ;D
Re:Keyboard Problem
« Reply #3 on: January 30, 2004, 19:10 »
It was her birthday yesterday too!   :heehee:
Re:Keyboard Problem
« Reply #4 on: January 30, 2004, 23:38 »
The "in" joke refers to this thread, for any of our newer members  ;)
http://pc-pals.com/index.php?board=28;action=display;threadid=827;start=0
You let yourself in for that one again Simon   ;D ;D ;D
