Author Topic: Windows XP and Norton Anti Virus  (Read 1185 times)
Offline PhilTheFish
« on: January 31, 2004, 16:16 »
I've just installed Windows XP Pro. All my program files stayed as they wetre originally, but I noticed that Norton AntiVirus wasn't starting up with my PC. I tried to uninstall it and reinstall, but when attempting the uninstall I got the following message.
Error 1606 could not access network location \documents and settings\allusers\desktop
Any ideas anyone?
Phil
Re:Windows XP and Norton Anti Virus
« Reply #1 on: January 31, 2004, 16:24 »
Hi Phil, try
http://tinyurl.com/3adfr
and
http://tinyurl.com/2jn4k
Offline PhilTheFish
« Reply #2 on: January 31, 2004, 16:42 »
Cheers Adept,
I'll have a bash tomorrow - going out on the ale in an hour.
In fact I probably won't be in any fit state to edit the registry tomorrow
« Reply #3 on: January 31, 2004, 16:54 »
Hey, just glad you have your priorities right Phil :drunk: ;D ;D
Offline PhilTheFish
« Reply #4 on: February 01, 2004, 13:47 »
Hangover's worn off and the links sorted the problem out.
Cheers
Phil
