Author Topic: processor question  (Read 1064 times)
Offline twiggy
processor question
« on: February 02, 2004, 21:54 »
after reading this artical http://www.build-a-computer-guide.com/Choosingaprocessor.htm i found that after eading thwe bit about the amd nameing "For example the Athlon XP 2000+ will be roughly equivalent to the 2000MHz (2 GHz) Pentium 4. The AMD Athlon XP 1700+ is roughly equivalent to the 1.7Ghz Pentium 4." well i have got an xp2400chip but my isn't runing at 2.4ghz like the article suggests. but mine is rnning at 1.9ghz?
couls someone expalin to me i dont understand ???
thanks mark
Offline dcys02647
Re:processor question
« Reply #1 on: February 02, 2004, 22:11 »
Have you built or bought your machine?
If you have built it, the manual or cd that came with the motherboard will have an explanation of how to set the processor up, either in the bios of via jumpers. Also read the docs that came with the chip.
 If you have bought it pre-assembled ask the supplier what the prob is & get them to fix it.
Hope this helps, if not, post again
« Reply #2 on: February 02, 2004, 22:17 »
I believe 'XP 2400+' is actually the model number, not the processor speed.  :)
Offline dcys02647
« Reply #3 on: February 02, 2004, 22:30 »
Ah!, now that puts a different light on things doesn't it.
« Reply #4 on: February 02, 2004, 23:29 »
Simons correct, AMD use model numbers not speed to identify their CPUs even the newer Barton 2500 is only around 2ghz, unless you overclock it.
My XP 2100+ runs at 1.7ghz, so yours is running fine as it is Mark  :)
Offline twiggy
« Reply #5 on: February 03, 2004, 00:29 »
o rite well that puts my mind at rest i just didn't expect a web site to make such a big mistake.
thanks all
« Reply #6 on: February 03, 2004, 02:10 »
Well its not really a mistake as such Mark, as AMD reckon that their 1.7ghz cpus work as fast as an Intel 2ghz due to the different way that each of them work.
So they call them by a number equivalent to the ghz of the Intel ones  :)
