Author Topic: 5 Things New Linux Converts Should Know  (Read 1122 times)
« on: June 14, 2010, 04:11 »
If you’ve recently converted to Linux from Windows, or if you’re just giving Linux a shot, there are a few things you need to know right off the bat about how Linux works and where the major differences are when compared to Windows. Some of the fundamental components are different between the two operating systems, and the way things are done can be drastically different; you need to learn these differences to be able to use Linux effectively, and to avoid trying to force Windows metaphors onto a Linux system that doesn’t accept them.
http://techthrob.com/2010/06/12/5-things-new-linux-converts-should-know/
- nice list here.
